radial tires
just mike
38
Has or is anyone running radials on a 09 to current street/road glide? If so what are your thoughts on them?
Thnx Mike
I would not use them. The suspension and handling is designed and tuned for bias ply tires.
From MotoUSA.com:
Bias and radial tires have significantly different dynamic properties. Bias, bias belted and radial tires have different construction types and therefore have different abilities to carry side and peripheral forces as well as having varied damping characteristics. The introduction of radial tires required changes to certain characteristics of the motorcycle. The development of the radial tire led to frame modifications, new steering geometries and suspensions. That’s why it is recommended that a motorcycle be used with the type of tire construction that it came with originally. Do not mix bias ply and radial tires on the same motorcycle unless it has the approval of the motorcycle or tire manufacturer.
If you have your hearts set on getting the radials then give us a review after the install. Thinking I would have a long discussion with who ever is selling these to you and have them give you a guarantee in case they don't work out.
kuchenvietnam
