Speaker Issues
Frase02
I’m a new member and have a question. My front left speaker is starting to break up occasionally. Is that likely a bad speaker or bad amp? Is there a way to know for sure? This happened one other time, I replaced the amp and it stopped. Is it possible I have another bad amp after a couple years? I’m a novice so go easy on me. Lol
Don't believe 2013 have an amp as I have same year. Speaker is probably going bad
Anything is possible, did you check all connections to make sure they are good? Can you pull the speaker and test it on a different power source? Or do you have a crappy speaker laying around you can hook up to the amp? Its pretty much gonna be a process of elimination if the wiring all looks good. Don't forget to check the tinsel from speaker connection to the voice coil of the speaker
jdtech17
