Tail light replacement filler
farmboy
176
Hey guys,
I'm thinking about changing the stock tail light set up to something a little different. I want to get rid of the bullets and move the turn signals somewhere else.
The problem is the 2 mounting holes in the fender. I was checking out some you tube vids a while back and I thought I saw someone replacing the factory light bar with a bar that didn't have the bullets, just a license plate light. That way the mounting holes are filled and you still have a LP light. For the life of me I can't find that video back again. Anyone know of a similar product out there? Also a led light that would go on the filler panel like the CVO that would use or cover the 2 antenna mounting holes. I've been considering the plasma rods but thought something on the face of that panel would be nice.
Any help would be much appreciated.
Thanks,
FB
Just a fyi if you are going to run plasma rods only you can not see them if the sun is hitting them just right, can be a safety issue!
Custom dynamics also sells a light that mounts on, or through, the filler panels similiar to the cvo setup.
If you mount the yaffee stealth 3 plate, you might have to drill another hole, but I believe the YS3 will cover the mounting holes from the turn signal light bar. I have not done this yet- so I can't confirm- but this is on my todo list. I already have the plasma rods mounted and working.
Crumb- The Plasma Rods are so bright on mine I have not noticed the sun affecting them but I do know since they are recessed you cannot see them from the side. I still have my regular tail lights though running CD LED's plus the Tri-Bar brake light.
Mandrew,
I've checked out the ys3 and I think that might work and give me some other options.
Thanks for the info.
PS.
I dropped off some chrome at HMC tues. Shawn seemed like a nice guy. Said my stuff would be done next week.
Mojo... I only have noticed it on a buddy's bike when then sun hits them just right when I am behind him, not to often but it does happen once in a while, it seems like it is usually when the turn signal is on.
Sancho
