Spark timing is another tuning table that YOU, or a professional dyno tuner, change manually when tuning your bike. The spark table should be properly shaped for achieve good performance and no spark-knock or pinging.
Here are the rows and columns of the front cylinder spark table from H-D for a 120ST:
Here are the rows and columns of the front cylinder spark table from my bike as tuned:
This could use a little clean-up, and there are also points with less advance than the stock tune (which did not have spark knock problems). I also noticed that the front and rear cylinder spark timing was almost identical. I don't see any reason for them to be different when a performance tuner is used and the fueling is richer than stock.
So I took the most advanced timing from each tune and averaged the front and rear cylinders to get these curves:
This is looking better. I then cleaned up the curves manually being careful not to advance the timing except at dips in the curves. This is the set of curves I am running with. I get really nice smooth performance and no spark knock that I can tell (I have not logged spark knock data my PowerVision tuner to see for sure):
When you edit spark for your bike don't just change single points. Edit the curves to keep the map looking smooth and sensible and without spark-knock or pinging. The ECM can interpolate better when the curves are smooth and don't cross each other. Measured data is full of scatter and needs to be smoothed out.
