USB Splitter
2015FlHXS
Aug 29, 2015
44
Is anyone using a USB splitter on the radio? I'm looking to play from a USB stick and also charge phome at same time. If so any sugestions on a small one that will fit inside the compartment.
I'd be interested in knowing this as well
Just a little information that may help with your charging needs. A couple of years ago there was a thread on here about changing out your lighter plug for a double USB charger power source. Looked like a fairly easy install just never did it to my bike because I carry a charging battery. Not sure if this would be an option for you.
I have never seen such a product. I suspect it would have limitations due to power drain requirements of the device to be able to playback in real time and also send a credible charge to your phone. How about adding that USB stick music to your phone and just play/charge from it??
I used this on my bike, very happy with it....unless you must have your cigarette lighter then this will work perfectly.
I use a USB stick for music, and had a Charge Port added to the Saddlebag. I plug my phone in, in the saddlebag, and it charges while I ride. The Bluetooth still connects as well
Adding a secondary dual USB charging port is fairly simple on Batwings and/or Sharks. I added a dual charging port in the pocket of a CVO I upgraded audio on a few months ago. There is an unused ACC connection on both RG's and SG's adjacent to the top right speakers. I use this connection for additional add-ons and put an inline fuse to it as well for ease of access. FYI
