No power
ferg21
6
I have a 2022 street glide CVO and I was replacing the saddle bags and changing the audio cut a wire it arced and now I don't have power to the front of the bike it won't start no radio power headlights nothing and Harley dealership can't figure out what the problem is they aren't sure if it's just the wiring and I have no idea what to do next anyone know what the problem could be
Assuming you checked the battery but guess you blew something. Hopefully someone here might have an Idea.
I checked the battery and all the fuses everything was good when I turn the key on I can hear the fuel pump engage rear lights come on but nothing in the dash or controls have power
How were the fuses checked, the pull out and look method? You can't always see the broken fuse that way. Use a digital voltmeter on ohms position to check them. Did your dealership test your BCM to see if it was good?
The dealership tried to check the bcm they said since they can't figure out why it's not getting power they can't accurately check the bcm
Wow, the BCM has to be removed and checked with a breakout box. I don't think they did that. Time to find another dealer or a reputable Indy.
Did you try to reconnect the wire you cut to see if your power would come back?
You’ve got life in the back but the front's giving ghost town vibes
2thDoc
