D DannyB New member Jan 20, 2026 1 0 1 May 22, 2026 #1 I am needing to either have a front bearing spacer made. Not a stock length , any ideas where I can get that done, Other possibility is to use 2 inner spacers cut to make up lenght, but is it ok to use two. Thanks
buck99rog Administrator Staff member Jul 20, 2021 289 109 43 Wednesday at 5:44 AM #2 Most local, to you, machine shops should be able to make a spacer for you. Personally I wouldn't use the 2 spacer method.
