08 street glide issues
ODMC
22
Was my on way to work and I lost all use of the throttle. Check engine came on and not able to use the throttle. anyone have the same issues here and what was the fix for it
Sounds like you lost the twist grip sensor if it's Throttle By Wire and not cables... if it's cables... check em...
yeah its throttle by wire. would that trip the check eng light to stay on after starting for about a minute or so?
Yes... TBW will throw codes and alert you like that...Check your DTC'S and post your codes....
throttle by wire was jacked up. replaced it under warranty and all good in the hood now.
