Going to be putting these on my bike here in a few days do I need new break and clutch cables? I'm sure it will be tight.But figured I would ask first.
12" don't require new lines... only thing you will need is 8" NAMZ extensions for hand controls.... TBW is long enuf
No new lines needed. Spazz is on point with his recommendation. I installed 12" Twin Peaks on my 2014 Street Glide Special and all I ordered was the 8" NAMZ extensions for hand controls.
Here you go Yamahoe.Josey, do you have a pic of the twin peaks installed?
Sent from my SM-N900V using Tapatalk
I installed my 10" black twin peaks but now my throttle side grip drags on the bar. It has enough drag that I don't even need to use the cruise control function. I took the grip off and put a light coating of silicone grease on the bar, that helped a little but not like it should be. Any suggestions??
