Calculate it here:
TwinCamComp
It calculates 194 psi for me.
I got 182psi with altitude adjustment using the Calculator. Thank you.
When I tested my Eng. I got 160psi front and 165psi rear ??
Let me explain I'm trying to find out why this bike is vibrating so much it keeps getting progressively worse, it is to the point where the whole fearing shakes so bad you can't see the gages this was first noticed during decel low RPM now it does it on acceleration also, but seems to smooth out some at 60 70mph in 6th mirrors stay still. I took the right side apart the runout is .001 I'm waiting for a T-70 to inspect the left side. I have been watching you and Spazz hoping for some clues. Any help you can give will be greatly appreciated
Also before I took it apart I took it to HD for warranty they agreed something was wrong!
I got this 2015 SGS used 840mi was told it still had a year left on the warranty. The
1st times I took in in for noise and vibration was told it was normal for this model the
2nd time the vibration keep getting worse told them I heard some noise in the primary they said they pulled off the primary to inspect and found nothing wrong and that they checked and said they realigned the motor with respect to the mounts gave it back
NO CHANGE I took it back they said they took off the exhaust and realigned it replaced front motor mount and swing arm rubber.
NO CHANGE. all the time I was taking it in for work they were stalling for time they had the bike off and on for about 4.5 months. I was finally told the truth, the first time I took it in they found out the warranty on the 120SE had run out (
1yr) When i got the bike I was lead to believed it was all under warranty except the normal ware items well they ran the warranty out. They were trying everything to fix the problem without touching the motor. And on top of that the work they did do with the mounts and exhaust HD kicked the warranty back because of the HD installed D&D complete exhaust.
NOT HAPPY WITH HD
I have to get pushrods I cut the HD ones, also heard that the SE lifters were not to be trusted do you have an opinion on these parts a recommendation? I was also thinking about roller rockers and rocker lockers what do you think?
