14" apes
dbmunson
What length over stock hydraulic clutch and abs brake line will I need to install 14" LA Choppers "Twin peaks" bars?
Thanks in advance for the intell..
I have 12.5" Chubby Baggers.
Both my hoses are stock. Maxxed out on the clutch. Brake had a little slack yet.
While I've never personally installed these bars, it might be worthwhile to take a look at the LA Choppers brake line / cable kit for the 14" bars...this way you get the perfect length for the bars since it takes the guesswork out of it.
https://www.ironacesspeedshop.com/shop/la-choppers-handlebar-cable-brake-line-kit-harley-davidson/
Hope this helps!
Lindsey :0)
I had my local hole in the wall shop install Factory 47 14" and they used my existing cables. I also have ABS. They just rerouted the cables.
Mikes469
