Hello all. I just installed 12" PYMB's on my '15 FLHXS. I've been reading and getting advice from alot of you guys, but I need your thoughts again on some issues. I went to the dealership and and got the CVO TBW 32310-08. When I was there they changed the molex pins to female so it would fit. The tech there wrote down the install order of the pins back into the plug ( yellow sleeve/black sleeve) and did it the way he said to.
Plug Cavity Order :
Yellow Sleeve
1- Black
2- White
3- Red
Black Sleeve
4- Black
5- White
6- Red
Put it all together last night and started it up to check. this is what I have now:
1- Check Engine Light On
2- No Throttle
3- Cruise Control Indicator on Gauges blinking " Yellow" ( will stay solid if I push in button on controls )
4- ABS light blinking ( did not disconnect cables at all during procedure)
Went into the DTCS section on the stereo and there are no codes logged.
Any advice or thoughts would be great. I'm heading to the dealership today to ask them as well. Thx in advance.
Plug Cavity Order :
Yellow Sleeve
1- Black
2- White
3- Red
Black Sleeve
4- Black
5- White
6- Red
2- No Throttle
