2015 shocks
Dvlhound
6
I I at learned that the shocks can have air added to them. I don't know a lot about this. Any suggestions on psi?
Ok which model street glide do you have a standard or special??? If it's the standard yes you have air shocks but do not use an air compressor to add air. Harley has a little hand pump to add air with. I think the max air pressure is 40 psi but I could be wrong. The special has hydraulic adjustable shocks with adjustment knob.
If you fill out your signature it would help us help you
Dvlhound,
In your owners manual you will find a section addressing the air shocks. There is also a chart for proper pressure according to your load.
As Tom stated above DO NOT use an air compressor to add air. HD sells a hand operated pump that can be carried in your bag.
Low & Slow,
Blues
Dvlhound- The shocks only hold a minute amount of air so a regular air chuck will damage them. HD sells a special pump but it is expensive. You can buy the same pump on eBay for about half the cost.
liedtke1988
