After Market Wheel bearings 2014
NWI
4
Looking to replace wheel bearing front and back. Am I seeing it correct 4 bearing on the back wheel and 2 on the front ? Who's a good aftermarket wheel bearing manufacturer? All Balls any good ? Who else is out there. Im getting a growling noise while taking swiping corners. Had all the confidence in the world while cornering with my 2014 street glide but this summer while on a 2,600 mile trip something happened and handling in cornrers turned to crap. Stoped at a Indy shop and had sterling head checked and all was good. I have a set of Comander II getting ready to put on but want to replace bearings while I'm doing it.
Nobody but bearing companies make bearings. I would buy the OEM ones from H-D. There are special features in them for anti-lock brake speed sensing.
I was getting the growling noise while taking corners. Had my wheel bearings changed. It turned out to be the tire cupping was causing the noise.
One of the bearings can be purchased from any bearing manufacture but the other side has an encoder in it so that the ABS sensor can pick up the wheel rotation., this one I think can only be purchased from Harley. I think that the harley part # is 9252 $33.95 & 9276A $23.95
Also, I would suggest not to try doing without a puller. You may have some tell you this and that..Dont do it.
Just my $.02
amelia.jam2005
