Almost a white stallion
Aidimack
8
Upgrade:
Header polished
TB polished
K&N Filter with 90 degree elbow (modified the elbow to fit with lower fairing)
Super Tuner
Replace complete set clutch assemble unit to Rivera clutch kit
Match painted inner & lower fairing panels
Replace front fork springs to Progressive mono-tube cartridge
Replace Rear suspension to adjustable Progressive rear suspension
Bridgestone 130 front & 200 rear
Installed original vintage HD driving lights
Trying to decide on cams.
Any suggestion is most welcome
Wow. Big work there. What are you looking for in your cams? Any reason why you didn't swap the cams when you did the header work?
How does it run?
Also- the matched inner fairing is a nice look for your bike.
Looks great! How do you like the front fork springs, very big difference ?
Looks good keeps us posted on what your doing with mods.
Thanks
Well am still debating on which cams to use, any suggestion?
I wanted to get feel of performance stage at a time, so at least this way I know what I have put into in terms parts & cash!..
How does it run?
Thanks,
Very big difference in corners, especially pair up with latest Bridgestone model, feel stable and much easier to flick the bike, the best for my riding style, front tire pressure 40psi & rear 42psi.
FastJonnie64
