Anyone heard of these CFR?
I have CFR slip-ons, but haven't rode with them. They do sounds fabulous in the garage. I also didn't want to spend $300-$500 in a tuner as im not planning any motor mods and im leaving the Factory cat IN. After a lot of research, i decide to go with Nightriders FL-Vied-10 http://sales.nightrider.com/fl-vied-10.html IT will add 6% more fuel and keep you out of the LEAN mode for the EPA standards. Priced right to, $126 shipped.
Thanks for posting that! I called them and spoke with Steve for about 30 minutes. He was very helpful. He told me that they made this product "Homer Simpson proof", meaning that it's pretty well dummy proof. It looks very simple. He told me to set the dial to 75%, plug it in and run it. It will add fuel to the mixture to reduce heat, reduce exhaust pop and add throttle response. For $126 shipped, seems like a no brainer. I ordered one today. He told me that the 2014 SG ECM compensates for 98% of the adjustment when you switch out slip on pipes and his product helps out with the small adjustments left over. Let's hope he is good on his word...
14FLHX, what setting did dial your FL-VIED-10 to? Did it set any engine codes or engine lights?
I too want to know... this is a great ' get me by for now ' until I complete the stage 1... any info you can give on what you dialed in on with the FL-VIED-10 would be greatly appreciated. I will be ordering the CFR's pretty soon.
Spazz there is a used set of cfr's on facebook group hd street glide touring for sale.
Guys- FYI - I had the VIED on my 2011 RK with V&H Power Duals, Stage 1 A/C and Rush pipes. It worked beautifully. I was very impressed and found no need to go any further ($$$-wise). It was one of the best values out there considering all the hype about tuners that exist. Hope this helps.
Thanks... I'll look into it!
Guess I need to call on the VIED... no results are listed for 2014 SGS on the website
Thanks guys... helps a lot
When I talked to Steve, he told me that the Vied-10 part #104 will work for my 2014 SG.
Steve is a great guy, I think i spoke with him for 40-45 minutes when i was research his product. Sure is nice to actually talk to the person that made the product.
Agreed. I'm sure he has been asked the questions I asked him plenty of times. His product is so simple to install and set up. I haven't seen one negative comment about his Vied/Xied anywhere I've looked. Mine was shipped today. After I finish my apes I'll do my Vied and post some pics.
I think I found the end of the rainbow.... one of my HD brothers just upgraded his 2013 SG to a Jackpot exhaust and tuner.... he said I can HAVE his VIED and his gutted stock header...:cool:
The 2013 and 2014 SG should have the same VIED.. am I right? If you guys can set me straight... please do... thanks!
duckworth
