Anyone tried these??
Here is the parts list. There is several company putting together the same basic kit that you can go through. If you look up JNR Designs on Facebook they make a cool compressor mount, which is what I have. You can also get the compete kit from them.
Bryan, What are you using the power lock switch for??? Air up and down?
Where do you get the fittings from, I have found most the other stuff on summit racing
The power lock switch is for air up and down on '13 and down bikes, on '14 and up you can either use a handle bar switch from legends or arnott or or mount a micro toggle switch on the bike. I got all my fittings from airedup.com.
I'm at 90 psi solo, can't get the wife on for 2 up, but I believe it's around 105 psi for 2 up.
Thanks for the help. I've done some reading, looks like guys who have had arnott and legends switched to this style and love it. I'm going to give it a shot!!!!
Funny this has resurfaced..... contemplating the build of my air ride... hmmmm
Just ordered up a kit from JNR
Comes complete kit including a bracket for $399 shipped.
Gregs41. I would like a little info on your gauge.
Looked on eBay and found a few, is that a 2" gauge?
What are you using?
Do you have a part number or link for this auto up/down switch?
Not ready to put on air ride, i did this easy install of Tamarack Machine Works. It drops your back end down 1.5 -2" for 92.00
Sorry for the delay, damn work is getting in the way. I got everything from JNR designs, look them up on Facebook. I finally finished my air ride this weekend and watching it auto fill and dump is bad ass.
It all depends on how far you want to take it, if you get all the parts your self it will be around $200 - $250. I've add a custom compressor bracket which is $45 and I'm add adding custom wiring harness that airs up once I turn the ignition switch on and airs down once I turn it off that was $120, I think.
I am thinking you have a normally open dump valve since ( when powered) it fills, being electrically closed and dumps ( no power ) when off... Right?
MotorNed
