Any one have any of the power commander or other type of device. I just hate the idea of going back to Harley for a tune every time I change or add stuff.
I used Power Commander V on my Dyna. Worked fine, and was fairly easy to program with canned maps. Fuelmoto has those and can provide maps for your setup. For my SG, I am using SEPST. (Screamin Eagle Pro Super Tuner). It's a bit more expensive, especially once you add the cost of the cables and software, but with SEPST, you are directly programming the ECM and can make and view changes real time. The PCV is a device that you plug into the ECM harness and it basically fools the ECM into providing more or less fuel (depending on how you setup the maps. Canned maps can be programmed into the PCV and it's fairly easy to setup and run. SEPST can be a little more confusing, but you can make and view changes to the ECM in real time. Also, with the SEPST, you can program other changes into the ECM not related to air/fuel mix.
I'm having an auto tuner put on this week with some new cams
I am trying to make the decision between the PC V or the Power Vision now. I get different view points from the vendors. I like Fuel Moto's customer service as I haven't a clue how to program or tune anything.
