Audio Help!!!!!!!
Nytelighter
10
So after reading countless threads, I decided to pull the trigger and install a RockFord Fosgate PBR300X2, Infinity Kappa 62.11i speakers, and a Biketronics BT335 Line Leveler on my 2015 Street Glide Special with 6.5 and stock flash. System sounds like trash. Messed with the settings on the BT LL a little but put them back to stock since the every forum I have read continues to harp on the stock setting from Biketronics is supposed to be spot on.
Setting on PBR300X2 - Gain 6, Filter (AP),
Setting on BT LL - Stock settings.
HU Settings: Treble at Center, Bass at Center.
Auto Volume: Off
I have checked power, ground, and speaker connections. Everything is square in those regards. Help!!!!!!!!!!!!:confused::mad:
Leave AVC off as you have.
Turn your amp gain all the way down... turn volume up to 2 bars from max
Slowly turn amp gain up til you hear distortion. .. turn down a tad
Sent from Note4 via TapaTalk
Did that same procedure already but I did it 4 bars from max. Turned up gain till I got distortion and then backed off. Will 2 bars from max make a huge difference?
Not really.... sorry. Could be the LL's...your input levels may be too high and distorting...
Okay redid it this morning and sounds a bit better. At the dealership getting a flash for 1 amp/2 speakers upset fairing. Hopefully I can get better results that way with line level inputs vice RCAs
Red2
