Aux lights
asmith1923
26
I just tapped into the cigarette lighter wire so they work on acc but ill change it to a console switch this winter. I did have to extend the turn signal wires though.
Tony
Did you get the switch and wiring for them also, and if you don't mind what did all the parts cost ya? Thanks
I bought the switch kit that came with the receptacle and two acc buttons. I purchased the fog light button separately. All the wiring I’ve done so far is custom.
Ive decided to re-wire them through a relay using the headlight power as the trigger so they are only on with the headlight. More in that once it’s done.
PS. Winter will tell if these things actually help with dark riding, but I’m not optimistic. At $400+ for these lamps, I would’ve expected more light.
El Guero Jay
