Battery Tender ?
Shep
15
Will a 2 pin Battery tender plug work with my 3 pin plug on a 2015 street glide special ?
Thanks
I did and it was not working.
Guess I better check the inline fuse?
I just got the bike and I was not sure.
Thanks.
Which plug did you use? Pull the left side cover off, and use that plug, I believe these bikes have 3 of them (for heated gear and what not) and some of them may be keyed hot instead of hot all the time.
I think you are using the wrong plug my 2015 as a two pin plug zip tied on the left side under the passenger floor board for the tender.
My battery tender was bad.
Went and got a new one and it is working fine.
Thanks Everyone.
Don't buy the H.D. battery tender it's a p.o.c. The one in the big ugly greem box that says Battery tender on it has worked the best for me.
I'm pretty sure the HD battery tenders are made by the same company as the green ones are. I have both and they are identical.
1biker- I hate to be the one to have to tell you this . . . The HD unit is made by Battery Tender
I've had the Harley one for five or six years and it still works as good as it always has
Gary L Barrett
