Biketronics BT4180.14 Info Rear Speakers Help Needed....
HarleyMac2014
I am going to install this setup and understand everything involved except one issue. I am adding saddle bag lids and speakers so my bike originally did not have rear speakers. With this being the case I do not see how I would install the rca input line leveler on the rear it appears I would just run the speaker wire straight from the amp to my rear speakers? My system has already been flashed to open the back speaker ports do to I am replacing the Harley Boom Amp Thanks for any info
IF you want to run your fader thru your head unit, you will have to do one of two thing:
1. Tap into the the harness for the rear speaker outputs
2. Buy HD's rear speaker harness
Now if you don't care about fade control ( I don't).... you can run your two front inputs into the amp and run all 4 speakers off the amp. It's exactly what I have configured.
