Boom Audio 4.3 stuck in Find mode
phxsunbum
6
I have about 200 songs that I put on a thumb drive that I connect to the USB input on my 2015 Street Glide. Worked fine until I wanted to find and play a certain set of songs, in the case 2 old Grand Funk Railroad songs. Problem is now that it will only play those two songs, so I switched to Nickelback, but now it will only play the Nickelback songs. I can't seem to get it to go back to simply playing all songs on the drive. Can't find how to get out of find mode in the manual.
Anyone have any experience with this issue?
Thanks in advance!
I don't necessarily have that problem but my radio still plays songs that I deleted off of my USB.... anyone have that problem?
Sent from my SAMSUNG-SM-G750A using Tapatalk
Click on find again, select artist- all, album- all, and then whatever song pops up first- it will continue to play off of your entire library.
Also on the menu screen make sure you have seek selected on the top left corner button and also the shuffle box checked I just picked up a 128G usb drive from best buy on sale for $30 and I have thousand's of song's loaded on it now I don't even bother with the radio any more
If you select "artist" it will play only that artist over and over. If you select "song" and shuffle, it will randomly shuffle through all the songs on your USB.
Doesn't it do that with only "shuffle" highlighted ?
It will do that if you select an artist, if you select "All" then it will access the entire library.
Exact thing happened to me. I eventually turned it off. I forgot what I did to undo it but it took me awhile. I will never touch that FIND button again.
Thank you all for your great feedback! I appreciate you taking the time to share you knowledge with me. Works like a charm now!
Bump-bump!
Trying to learn as much about my audio system as I can so I've been searching through the old threads here. I dislike the radio portion of the 4.3 Boombox so I've been bluetoothing my phone to it. Can be a PIA at times so I'm always looking to improve it. I've got about 500 or so songs on the SD card, plus some songs on youtube (uses data so I quit that) that I found. This thread gives me another option I think.
So if I copy my music to a thumb drive, I can plug it in via the USB in the jukebox? What source will it use?
Any info will be greatfully appreciated. Thank you.
Got it figured out and loving it. Copied my phone music to a thumb drive, plugged it into the USB port and set it up using the seek and shuffle selections. When I turn the ignition on, the last song playing resumes and I just wait a second for the acceptance screen. If I want another song, I simply move the selector toggle right, or left if I want to start from the beginning. I've got close to 500 songs with room for more. This beats that lousy antenna anyday!
noithatquetram
