Boom! Audio 6.5" Fairing Speakers Stage 1
t8ness
Aug 25, 2015
40
I purchased these to pair with RF PBR300 AMP to go on my 2014 Street Glide. The speakers could not handle the power. They blew out, returned to Harley for warranty. I just received them today, opened box just to verify contents.
*note this set does not come with the grills. Harley only warrantied the Speakers
$150.00 shipped OBO
Will stick covers fit?
I have these speakers and they are about a 30% improvement over the stock speakers when used with the STOCK radio. They sound very good for the small amount spent.
I held up the old speaker grills to compare with the grills that come with these speakers and are mounted on my bike. The stock grills are flat while the grills that come with the kit are bumped out about 3/4" to allow room for the suspended tweeter. I cannot say the stockers will not fit BUT it appears that there is NOT adequate clearance for the tweeters with the stock grills. That said you may be able to find a pair of aftermarket grills that will work or possibly modify the stockers if you are handy.
So are these just plug and play if you have the stock 6.5 infotainment system. They just add the tweeter correct?
Yes, and if I remember correctly the magnet on the larger speaker is considerably bigger and heavier also. These are 6 1/2" diameter which is about an inch bigger than the stockers and they are rated at 75 watts each. I think the stock speakers are 25 watts. Make sure the part number is correct for your application. There is more info in the HD P&A catalogue.
The speakers are great over stock. I just went entirely aftermarket. They can't handle an aftermarket amp if that's what you're aiming for. But just to upgrade over stock. Pretty decent
If anyone is interested I still have them. PM or message here. I really have no use for them
Teddiebear
