Boom Box Question
DebbieW
May 17, 2016
77
How do you see turn by turn directions listed when following an uploaded route on the navigation? I have been told there is a way but can't figure it out. That was a nice feature when I used the Garmin Zumo 660.
Put your route in select it and let it route it for you and at the bottom of screen select or tap it and it should show you turn by turn
Yep, what dmead2 said. When you hit "Route" and then "Go" when it's finished calculating the route, you will see your first navigation instruction at the very bottom of your screen. Just hit that and it will show you the turn by turn route.
Thanks. I can't believe I couldn't figure that out. Technology challenged I guess. Will check it out this weekend when I load a route.
El Guero Jay
