CB Antenna Bracket of 2018 SG
PWS
6
Hello all. I want to install a cb antenna through the fender skirt on the right side of the bike--looking at it from the rear. The dealer sold the cb antenna kit but the bracket is for the left side. Dealer said to bend it to make it work. Well I bent it to and it kinda fits I don't like it- problem is that the antenna will sit 1'-1 1/2' lower than the left. I have researched and haven't come up with a good fix. Has anyone else had the same issue and what was the fix.
Thanks
I found this information on another site.
Matching antenna mounts for AMFM & CB
I just bought the tour pak quick detach kit for my '09 FLHTCU (PN 70032-09), which comes with the AM/FM antennae relocation kit, but not the CB mount. The AMFM does not just clamp on, but mounts to a tab/plate on the saddle bag frame. The CB antenna kit (PN 76410-09) is a clamp on that would not match the left side exactly. Finally discovered that the harness kit PN 53246-09A had the exact mirror image mount for the right side.
Both those kits have parts you don't want/need. The parts for the mounts only are these:
Left side (AMFM) - PN 76557-09
Right side (CB) - PN 76504-09
For each one you need two torx screws, #10-24, PN 2441
These part numbers and more, for lock washers, antenna adapter, antenna cables are on the back page of the .pdf instructions for the QD kit and harness kit, PNs above.
But if the SG does not have the tab with screw holes (per dansflhti), you're SOL, and will have to use the clamp on. But maybe this info will help another Glider...
Thanks for the information. I bought the cb kit that included antenna , cable , bracket and the fasteners. The antenna bracket is # 76000183 which is left side. I will check the numbers you listed and see if that will work for me. I would take a picture of the bracket but I may have ruined it by trying to bend it to fit as the dealer suggested.
Roughouse_R_75
