When I started checking if this was even possible my dealer said no, others said yes. I'll be doing a long cross country trip next summer with my brother so I wanted to install the CB to listen for speed traps, traffic updates as well as communicate with my brother without slowing down and yelling at each other.
Well, I found a HD Press Release that says it is possible second to last item under Boom! Box 4.3 states; Boom! Box 4.3 supports CB radio and voice-activated (VOX) intercom functions.
So I went and ordered the parts, so far I'm still waiting on the connection cable (coming Friday) for the headset as well as the headset itself (back ordered until 3 Jan). I ordered the parts from Surdyke as they had a 20% off sale, my only complaint is that UPS is delivering everything on 3 different days. If the headset gets delayed any longer then I'll order this one from IMC Motorcom
I started the install of the CB on my 2014 Street Glide today. I'm taking pictures as I go as well as making a good instruction sheet (PDF) that I will post up when I'm done. So far the module is in, pretty easy but you'll need someone with small hands to get one of the bracket screws in.
The antenna I ordered is the wrong one, fits up to 2013 so the bracket will NOT work on the 2014 models, so off to the dealer tomorrow to see if I can get a bracket or if I'll have to make one.
The instructions that came with the CB module are incorrect, the CB module plugs into the BLACK plug not the one on the directions. No big deal really as the plugs have specific fittings and you can't get it onto the other one which for now I assume will be for the comm cable.
Stay tuned for updates...
