Cheap LED Headlight?
Just installed this. I bought it off of Amazon for $60.00 . I had to cut out the back housing for it to fit with tin snips. Best $60 Ive spent
It's not quite as bright as Harley's Daymaker....
Headlight Type: 7" Round
Power: 45 W LED
Quantity: 12W x 4 Input
Voltage: DC12V/24V
High Beam: 3200 LM
Low Beam: 2400 LM
AUDEW 7" MOTORCYCLE CHROME LED PROJECTOR DAYMAKER LIGHT
Power: Low beam 30W / High beam 40W w/ Projector
Lumens; Low beam 2000LM / High Beam 3000LM
Color Temperature: 6500K-7000K
But probably close enough......
As good as the HD Daymaker is/was- there are many newer technology lights out there including the Custom Dynamics Halo Ring that are even better. Same is true for certain bulb replacements for stock dual bulb Street Glide headlight.
Unfortunately, there is some cheap knock off junk out there too. Beware of the really cheap stuff online.
Haven't tried this one but I bought a cheap sunpie off Amazon and it works great!
-Superior Blue 2017 Street Glide Special
-7" Sunpie Projector Headlight
-TAB Performance B.A.M. Sticks 4" Slip Ons Zombie Baffles
-Khrome Werks +2 Wide Bars
-Custom Dynamics Front & Rear Turn Signal Inserts
-Kuryakyn's Lower Triple Tree Wind Deflector
-Harley Adjustable Driver Backrest
-Long Ride Shield Recurve 7"
-Dark Smoke Air Deflectors
-Harley Upgraded Tri Bar
Sounds great. Did your Sunpie fit into the standard hardware, or did you need to buy their adapter ring? Thanks.
Sent from my SM-G930F using Tapatalk
+1 on the Sunpie, have had for a 1 1/2 years with no issue and only another $10 or so over the Walmart light. But they are probably made in the same place??
Mikes469
