Cirius Lights wired to Aux light Switch
I'll start off by saying that the Cirius lights are high quality. The finish is excellent and they do not rattle. I found the hardest part of install was tapping the holes for the screws that mount lights. I would recommend using painters tape on bars to make marking and drilling easier . I broke two taps while tapping which meant a couple of trips to Lowe's. The lights do not have rubber seals. Cirius lights require silicone sealant for sealing lights. First one was a little tricky but the rest went easy. Using to much sealant could cause some of the sealant to get on lights. Won't hurt the lights but may obscure the brightness. I had the wires exit the top of the bar just about center. Fishing wires was not that difficult.
Now hooking the wires up to the bike for newer bike was the difficulty. First I didnt want a cheesy looking hookup so I had to invest in the aux. switch harness from harley. About 130$ after tax. Second , I hired someone to do the wiring. That was almost as expensive as the lights. I installed two whites facing forward and two reds on bottom facing back. White lights I had installed to turn on with the aux. switch and reds I had installed to turn on when brakes were applied. I tend to overthink things and over research which leads me to uncertainty. So for a bike I paid 21,000$ , I wanted to make sure wiring wAs done right. In the end everything cost me about 750$ -800$. This was a little more than what I wanted to spend but the look is awesome and it does draw attention. I wanted something different and Biketoberfest in Daytona proved it.
So yes I would do over. Hoped that helped. Sorry I didn't take any install pics. My lights look exactly like ones on Cirius website.Super bright and I love them. Any more questions message me. Be glad to help!
Sent from my iPhone using all Tapatalk
