Dealer Location Update
Just downloaded 1.20.2l and now have nothing but the bar and shield and the time, no controls work.
Only had the bike for 3 weeks so don't have a copy of the previous version (1.20.1) does anyone know where I can get a copy till they fix 1.20.2l?
Thanks in advance
This sounds to me like the audio got turn off somehow. Push and hold the on/off button (bottom right button on the special) until the audio system comes on and see if that works.
Well after playing with mine a little more, I noticed two things: 1) I use a USB drive for music and although I can go into the menu and select whatever song or artist I want to listen to, once selected, I can't select the next or previous song using the left control and that song just repeats over and over, and 2) everything seems slower when using controls to selected the source, volume, or navigate through the menus. I guess its back to 1.20.1 for me.
yep... this has happened to many of us.....
Just shut the bike off for 2-3 minutes.... this is all I did.....
I reverted back to 1.20.1 and so far... not instances of a dead head unit for me.....
Didn't see the post about holding the power button but got the unit to work through the info button and then into the menu after hitting the left hand control, it still acted weird but after several more on/off cycles seems to be working now.
Yep, that's what I did and all seems to be well.
Weird problems you all are having. I let my bike sit for two days since the update. :( But I just got back from a 30 mile test-ride where-in the radio and heated gear were "tested" as well as the battery charged. Ah hell, I went for a ride! LOL
Any way, the radio works normally for me after the two updates. I even shut the bike off to get gas and the radio came right back up. I hope it works out for every one.
David
After I reverted back to previous firmware build . . . . no issues. I think I'll leave well enough alone.
Me too... no issues after I rolled back to 1.20.1
Sent from Note4 via TapaTalk
ATENTION
MOCO took 1.20.2 off the download site.... they must be aware of all the issues...
If you need 1.20.1.... it's on MOCO' site once again...
ATENTION
Ha Ha! I knew sumptin was up!
I have always wondered if Harley has gone through these problems with the firmware in the ECM and security modules. Imagine them having bugs in customer's rides!
David
Sancho
