I acquired a stock header from my buddy in exchange for installing a decatted header and mufflers on his 2017 RGS. My plan was to modify the header to my liking. So far, I have cut out a section from each primary tube and will be replacing those sections with 304 stainless steel and an 18mm o2 sensor bung in each. I purchased a chain style exhaust pipe cutter and cut the shell on the catalytic converter. I then removed the cat (for off-road use only), by drilling holes and using a pipe to knock the cat out. I still have to clean up a little residual cat material that remained stuck to the walls of the shell and bevel the two halves in preparation to be welded. Once I get all of my parts in hand, I will take everything to my buddy and have him Tig weld it together. Here are a few pics.
