Looking to get opinions on both the Dirty or Skully Air? Who's got the better set up with less problems... And go....
I had a scully air system installed at the TLSR last November for 700 bucks and have been very happy with the performance of the system. pay the extra 80 bucks for the switch to be mounted on the handle bars as it makes it easy to adjust while riding.
You might try the search feature in the upper right corner of your screen. There are several threads on here about air ride systems
When riding at different height will tension on belt change hence causing pre-mature wear??
I adjusted my belt tension based on my typical ride height - but i JUST did that. I rode 4,500 miles without adjusting my belt tension and had no issues
Sent from my SM-G930R4 using Tapatalk[/QUOTE
Thanks, yes i contacted dirtyworjks and they stated to get my desired ride height and adjust belt tension per oem spec,
