DIY Air Ride
  • Thread starter Thread starter steve73
  • Start date Start date
S
steve73
Guest
ARO P251SS-012-D Solenoid Air Control Valve,1/8 In,12VDC
Viair 98C 12 Volt Air Compressor Kit w/Omega Bracket
Viair 40amp relay
Monroe MA785 Max-Air Air Shock Absorber
With bushings and welded eyes
Air Lift Company( P/N 26227) 200 Psi Single Needle Gauge. This Gauge comes with a backlight bulb, that is a amber color. This Gauge measures 2 1/16" ( 2.0625") in Diameter and will fit in 2" Diameter hole.
Reading Design On/Off Toggle
$210 Shipped
Used. Not on the bike for long. Everything is in excellent shape.
Our streets here in Iowa are absolutely terrible. Could never find the right pressure. I went with progressive 944's.
How do you like the 944 progressives? Did you go with standard or heavy duty spring?
I went with the heavy duty springs because I ride 2 up 95% of the time. The ride is great. I don't have any complaints.
Thanks. The stock shocks are pretty bad especially 2 up. Weekdays I can handle just me on the bike but weekends w/ the wife I know she suffers. I don't need any going up and down air ride - I just want a good ride! Will probably get these.
