Fairing not seating correctly with LRS
Spike
26
Got my LRS ultra wide, install was easy, but the windshield won't allow the fairing to seat properly on the gasket. There is a 1/16th inch gap that tapers down on both sides. Any ideas as to why?
Likely because of the thickness of the windshield. I seen where some people were adding some type of weather stripping. I also have the LRS but for some reason I don't have that problem. I'm sure you already checked but are you certain the fairing and the grooves in the shield are lined up correctly, especially if you have a windshield pouch then they all three have to line up perfect. Did your shield come with weather stripping to put in the gap ?
No weather stripping included, lined up correctly, no pouches. It's as if the shield doesn't match up with the curve of the fairing.
Mikes469
