B Bri New member Jul 28, 2016 7 0 0 Jul 28, 2016 #1 Will a stock 2016 street glide front wheel fit my 2006 street glide? I know it's not a direct bolt on but just wondering if anyone is doing it. Thanks
Draztik New member Jul 28, 2016 1 0 0 Jul 28, 2016 #3 This is my 2006 with a 2013 wheel. Stock 1" axle. had to replace the bearings and 1 spacer. I would assume that a 13 and 14 wheel have the same mounting axle/bearings/spacers. I believe you can also opt to replace your 1" axle with the newer 25mm axle. Let me know if you have any questions.
B Bri New member Jul 28, 2016 7 0 0 Aug 1, 2016 #4 Did you use your rotors? I have read they are the same bolt pattern on the rotors. I don't want to buy new calipers and all that.
