Fullsac Exhaust System Install
What tuner do you like?
Also thanks for input
I had the FP3 on my 14SGS with V/H PROPIPE and ran flawlesly... recently did a 15 Limited with powerduals and high outputs and FP3 and runs fantastic... also did a 15 Trike with Powerduals and V slash cuts and FP3... another great runner...
I have moved onto the Power Vision now with 15 RGS and love it.
I would have stuck with FP3 but would not do me any good with my 120ST. The PV does a lot more than the FP3 and I needed it
Sent from Note4 via TapaTalk
SE high flow Exhaust is designed for 110's and bigger... you will not get a good tune with that pipe from any tuner...it's too big for your 103.
According to H-D that exhaust will work fine on a 103. Here is a performance plot from the 2016 SE catalog. Looks very good to me.
Time for a tune think I'll try it myself. Not good with pc's but I can read an learn
Thanks hulk
Had the Fullsac DX pipe installed with a set of V&H Monster Ovals a while back. Sedate and deep note, sounds great when you get on it. Had to adjust headers out a fraction to the right to sufficiently clear the rear brake plunger bolt (it did clear but was very close when engine was running and moving around) which meant spacing the right footboard out a few mm, and if you look really close at the mufflers from the rear they aren't QUITE dead centre (OCD ALERT LOL) but no clearance issues now. It probably would have been fine, but oh well it's done now!
Very happy with this setup. The tune (local dyno tuner) is great, I'm actually reconsidering even doing cams. Runs great for a stock motor in a big bike.
Great posts and pics! I removed the baffles from the CVO cans, installed the ceramic coated Jackpot X-pipe and added a SE heavy breather with a HD stage 1 download...pulls a lot harder and sounds bad ass 👍
Sent from my SGH-T889 using Tapatalk
I'm also having the Fullsac DX head pipe and a custom tune done to my girl this week, going to be a long week.!!! I'm using my RC mufflers this thing is going to be off the hook.
Iv'e been very pleased with my set up after adding the Full Sac. The nice thing is it looks stock but if far from it.
aj77donovan
