Half disassembled Glide
Dread_Sled
31
So going on day number three of trying to install my mini-apes. When I skimmed the procedure for replacing the handlebars, I never would have imagined that my bike would be laying half disassembled in my garage, all the fairings off, fuel tank off, etc. As I was trying to get the outer clutch cover off last night to replace the clutch fluid line, I realized I was going to have to remove my power duals because the cross pipe is blocking the cover. I also discovered the copper washer between the fluid line and the secondary clutch actuator is not included in the replacement line kit.
I was also reading last night that if you touch the brake system at all on an ABS bike then it has to hooked up to the Digital Tech II to ensure there are no bubbles in the system. Does anyone who did their bars know the details? Am I going to have a non-functional ABS till I take it to the dealership?
Lot of steps involved for a handlebar. Eight days to Rolling Thunder. Hope it's put back together by then!
Ugh ! Spazz may be able to chime in with assistance-he's a pro with the mini apes
It's back together now. Took me and my dad 4 nights after work to get it all done. This is my first time tackling that much disassembly.
Has anyone found a good solution for plugging the mirror holes? My dealer told me Harley doesn't make them anymore.
Mandrew, that's an awesome idea! I like the look of the Willie G skull
These will certainly do the job and little less expensive than the Yaffe option.
Dred_Sled- I saw this treatment on a RG in Denver recently. Same color combo as yours . . . .
Looks good. Did you take it to your dealer to bleed your brakes? I just took my to my Indy to do my this past Saturday.
Thanks Bryan, I took it this morning. We did a decent job but needed to get the ABS reset.
Mojo, looks pretty good. I think those pipes are growing on me. definitely creative! I may very well do the red calipers but prob do them myself like some of the guys around here. One of these days, lol
Dread_Sled, you can certainly save $ome $$$ painting yourself!
noithatquetram
