Help needed with Rockford HD14-TKIT on my 16 Streetglide
simmons5
10
I need some Audiophile Help please. I just installed the Rockford Fosgate HD14-TKIT. Front Speakers and Amp kit. Here's my Problem. When the bike gets up to 4th gear or so the right speaker consistently cuts in and out. I have the Amp set on the factory specs from rockford and all the connections are solid because when the bike is Idle there is no issue. I'm playing music through a dedicated IPOD that is plugged into the bike. Any Ideas ?
I am going to install this soon. Did you solve the problem? Any heads up you can offer would be appreciated. Any special tool you wish you had during installation? Thanks.
They replaced my entire system. I posted the tool you need in your other Rockford thread.
10mm Flexible Pivoting Head Ratchet Combination Spanner wrench
