Help Speaker Problems
SG14FS
I just installed a J&M Rokker Fairing speakers and amp. Now every time my air compressor kicks on and off, my speakers pop. Any suggestions??
Hit up Chaderick... he had the same issues you are having. He got it fixed... not sure what he did though... can't remember
Sent from Note4 via TapaTalk
I hit up Chad... told me.his fix was a ground loop isolater
So... I tried the ground loop isolator and it didn't help at all. I have checked the ground on the amp, all the way up to where the power line goes in the amp. When I take the amp out of the system the popping stops and everything works like it's supposed to. I have checked every ground I can find on the bike. They all are tight and working per the multimeter. This leads me to believe I have a problem with my amp. Anymore suggestions would be greatly appreciated.
One more thing... Sometimes I'm getting the popping noise when I turn the ignition off as well. But... only when the amp is hooked up.
If you take your amp out of the equation... still popping?
Sounds like you found your culprit...call John@ J&M
Hockeyguy26
