Higher seat
Jakes01245
4
I’m looking for a seat that will lift me up a little bit. Maybe an extra inch or 2. Any suggestions?
If you ride solo you can get the police solo seat and suspension from H-D. It uses a coil over shock suspension and is super comfortable.
I swapped out my stock 2008 Streetglide seat for a stock Ultra seat that was taller and wider. Mostly for passenger comfort at first, but after a 1000 miles I like it better.
Thanks for the replies. I’ll keep my eye out for the ultra seat.
I have a police seat that I’m going to try this weekend.
I put the police seat in. Now I need to decide if I want to spend the coin on a spring or do the kong thing
The newer design from H-D is a coil-over shock which I think is much better.
I can’t believe the used availability on them. I was thinking I would see at least 5 on eBay. Just one!
Corbin Tall seats raise you up 1/12” also move you back 2”
What year bike? I have an Ultra Classic Low set i took off my 2017, Previous owner was Hight challenged. This seat pushes you forward and I think technically drops you a smidge lower. I swapped it out for the stock OEM SGS seat. I think retail it is about $375. i will let it go super cheap you could even afford shipping.
Luis streetglide
