This should work:
Use the BOOM 6.5 head unit on my bike to run two new upgraded speakers in the fairing
Buy a " DSR1" american hard bagplug n play harness. This harness allows you to gain rear channel output from a bike that did not originally come with rear speakers. This is ideal if you want to add rear speakers with a new amp and be able to use the fader option from your factory Harley radio. Should also work for adding two speakers and an amp for the lower fairing i installed. The fader would then switch between upper and lower fairing speakers.
So 4 new TMS65 speakers total $538 - the harness $ 70 - and 2 channel Rockford Fosgate amp $ 200
TOTAL $ 808 Flashing required so add for that.
WHAT SAY YOU ?
WHAT SAY YOU ?
