how many quarts of oil?
bigguns55
16
How many quarts of oil does a 2016 street glide take with the filter?
The owners manual says 4,but every else says 3.5.
You will need 4 quarts but you will probably only use a little overs 3 1/2. Put in 3 1/2, run it for a minute then shut it off and check the level.
I always put 4 quarts in mine with a filter change. Many say run 3 1/2, but I personally would rather make sure I have enough rather than too little oil, especially after spending lots of cash on my hot rod motor. Having said that, I do get some blow by periodically whenever the oil filter gets saturated with oil, but I'm not 100% convinced that this is caused by running 4 quarts of oil either.
I put three quarts in mine a 2015 and unless they changed something in 2016 the book says to start with 3 quarts. (Page 149 of my book) Mine has always been right in the middle of the dip stick where the book shows it should be. I don't get any blow by either, and I don't add any more than the original 3 qts.
M8's take 4.5 but I always run 1/2 lower-No vapor blow by in the air cleaner either!
I start with 3 quarts, like the book says, then after running the engine I use the dip stick to measure a fill to just below the full marks.
I'm with OldMike. If the manufacturers suggested methods, as printed in the manual, are followed things always seem to work out fine.
El Guero Jay
