I installed a JW Speaker 8700 Evolution 2 LED Headlight on my 2016 Street Glide today and decided to document the process to give something back to the forum.
You will need an LED wire harness kit to install the headlight. I purchased the one from Harley part No. 69200897
1. The instructions state to disconnect the battery prior to installation. However that sounds like too much work so I removed the main fuse instead.
To get to the main fuse, remove the left saddlebag and left side panel:
Pull the main fuse:
Pull the main fuse:
