howling in turns
jolson
Hello I have a 2015 SG Special I noticed today that when I lean into a left turn or cornering left I get a howling noise. Any Ideas what I should look for?
If you are running the stock tires, they are probably starting to "cup" along the edges which results in the howling noise you are describing.
OP, at that mileage and if you are still on the OE tire, your problem is absolutely wear and/or cupping. You might not see cupping, but it is likely there. If the tire still has miles to go...embrace the howl!
Some tires...such as my own 888's...howled from the get go.
howling in turns
Listen for it and it might be the rear. My have 16,000 miles and the rear makes the same sound in sweeping curves.
I'm late to the party but I just got new tires due to the Duncrap cupping at 7k. Love my commander II's.
chops92
