Info needed on 2014 Street Glide rear speaker output plug...
HarleyMac2014
I just want to make sure this is the correct plug with rubber cap inserted that I need to hook into for rear speaker out put. Im going to put it all back together n hopefully have it flashed to open up the saddle bag lids...20160410_183419.jpg
From that picture and the color wires, I believe it is. You can do a couple things, 1 test for signal after the flash (or now which there shouldn't be) who's ever plug and play wires your using should be color coded the same, with the female matching plug.
Thanks
For what biketronics confirmed it is the correct plug but to stay away from Harley for now on the flash an soft ware update until they get the bugs figured out. So rca y splitters from the front line leveler to the amp opens all four speakers..... for anyone who has not had a chance to here biketronics bt4180.14 amp it is well worth the money and then some.....
