Inner fairing removal
rockman450
How can I remove the inner fairing/ radio trim on a 2018 street glide special? I need to adjust the factory handlebars. I removed the trim piece below the radio to expose the allen heads for the handlebar clamp, but the radio surround/ inner fairing cover is blocking most of the access to handlebar clamp bolts. Thanks!
Outer fairing comes off the remove turn signals and or passing lamps. Renove studs and your inner fairing is loose. Lift up a little the rock it forward....
jdtech17
