Installed HD passing / fog lights
I just installed Kuryakyn driving lights with a harley switch in the "dash". The switch illuminates and the relay "fires" but the driving lights wont turn on. Any ideas? Thanks
Well i brought my SGS to the dealer yesterday. The parts Dept. sold me the wrong switch, that's why they wouldn't turn on. They took it back and one of the mechanics installed the correct one at no charge. Thanks for everyone's input.
I ran across this past thread:
If you ride any dark back roads this might be something to consider adding. This wiring harness kit allows independent control of your bikes auxiliary lamps (passing lamps). It allows the passing lamps to remain on when the headlamp is in either low or high beam settings. Normal operation is the passing lamps are turned off when HIGH beam is selected. This harness allows you to have HIGH Beam and passing lamps on together.
http://www.harley-davidson.com/store/independent-control-auxiliary-lamp-wire-harness-kit
Glad you got it figured out!
MoJo - the harness is for 13 and under, 14s up its just a quick flash.
Eric375
