Installing Paul Yaffe 12"bars
I would think the HD heated grips would fit correctly. It's the wiring of the grips that I need to figure out. Especially on the throttle side. If I get the CVO tbw wire harness, I think I may have the room in the bars without the connector plug in the way that comes stock on ours. Not sure yet.
I apologize in advance but I'm a little confused. To do this I will need the wire extensions for the controls that I follow. But is there an additional extension for the heated grips as well? Also, once the connections are made in the bars, do the grip wires plug in at the fairing as well? I'm reading about having to run wires to the battery for power, I thought the 2015 had all connections available upfront. Did paul65k post this install somewhere? Thx...
Look for the post called "anyone install hd heated grips" it's in this section of the forum
Fx84carl
