Ordered this from Direct Cycle Parts. Best price I found. Never received any order confirmation or tracking from them at all. An invoice would be nice also.
This kit has the amp, speakers, two different brackets, hardware, a music test cd, instructions and harnesses. I think J&M should throw a sticker or two in the box for my garage as well. I thought the kit was well put together. A true plug and play. You do have to remove the tank to install correctly in my mind. Not hard to do at all. Pretty simple. Obviously, the outer fairing also needs to come off. Overall, a very easy job. Turn the garage tunes on and grab a cup of coffee.
Just getting started.
I also replaced the OEM antenna cable. The service tech at the dealership jacked mine up last spring when they put in a HD hidden antenna. Which is now removed and replaced with a J&M hidden, non-powered antenna. I have the inner lower cap off because I did the fork spring swap on Friday evening. I wanted to do all of this at one time.
Stock speakers gone.
