JNR Designed Air Ride Switch Kit
16FLHXS
32
Just ordered it.
Anyone else have these? Do you like them? Do they function well?
I like the idea of using something already there with a Factory look (atleast regarding switches, gauges, etc.)
I ordered the factory CVO switches for my air ride and plan to install them this winter. I was not aware JNR sold that set up until after I had ordered right from HD. I'd like to see how he sets his up as I will be wiring from scratch. My switch is located underneath right now so it'll take some getting used to with them being on the dash. I like the clean factory look.
Got any part numbers for the factory CVO switches? I plan on adding them this winter as I like that look also!
I have a 2016 flhxs that I am getting ready to install an air ride on. It appears I need to order H.D. part # 71400035 & 71400036 to control my air ride. If I understand correctly these will fit into the existing switch locations on my dash filler panel and then wire them thru relays to control the fill and dump valve. Am I missing anything on these switches?
